Cheap 12" drivers
I am looking for a pair of cheap. let me reiterate CHEAP!!! 12" 70watt 8ohm drivers.
can someone hook me up with a good site?
this is for a sub-woofer modification for a vented two speaker sub-woofer box from a car audio system.
I have already purchased my amp from apex jr. I got the Cerwin Vega ARPHU2003 SubWoofer Amp rated at 150 watts.
I am not sure how this will sound in my home audio setup but I think that it will be more than enough for my needs. I don't listen to much music but would like that good thump while watching movies.
I know that it would be better with a more powerful amp and some 100 watt speakers. please don't be to harsh of my plans.
thanks for the link. I think I found a good 12"
just want to ask to make sure this would be good for my application
the DAYTON DC300-8 12" CLASSIC WOOFER
rated 8 ohm 80 watts
If I use two of these with my 150 watt amp everything should work ok right?
I think that this setup is optimal as the two speakers will equal 160 wats giving me a 5 watt per driver leway. Im not sure about this stuff so your input is appreciated
here is a link to the driver
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-320
I also failed to mention that the efficiency of the shielded dvc 12 is 94 db compared to 91 for th eclassic wooffer this along with the xmax advantage maeans that 1 shielded dvc 12 would be very comparable (on the same 150 watts ) to 2 classic 12 inch woofers and probalby much better suited for a subwoofer and cheaper
