Chassis for DIY MonoBlock Tube Amplifier
If you can use this, here is a great deal for the DYI amp builder:
This is a symmetrical pair of chassis for a tube amplifier.
The lumber is rosewood….. about $50 worth
The top plate is 16ga mild steel, with holes for 4 octal sockets (1.12 dia)
Note: if you have to change the location of the mounting holes, small holes and be patched with JB Weld, the top plate re-drilled and re-painted.
Outside size = 13.5W 14.75D 3.50H
Inside size = 10.5W 12.50D 3.25H
Weight = 9.5 lbs each
Please see this item on ebay if youre interested
320334078622
Added a photo
