ok so my charlize amp work fine but it wen y try to put it in a boxe I don t understand why it does not work
then I put it out and wire it outside and it work
there is something I dont get
my casing is aluminium ???
help please
help please
First question: are the RCA input jacks and output binding posts insulated from the metal chassis?
Can you check the resistance between each terminal with a multimeter? They may look fine but you never know. Since it works outside your case it's obviously a problem with the way you're wiring it inside the case.
