I just want to ask this maybe weird question, I never heard of this circuit before but does it exist
It’s a controller you connect between a battery and a wind-generator and then on the load
So should work:
If the wind-turbine is generating electricity on a windy day it must charge the 12V battery’s and then you have a load like an inverter the controller must sense the best option to source the inverter and in the meanwhile charge the battery if the inverter doesn’t drain to much electricity. And then if all fails it must just run on the battery.
So should work:
