Changing TDA7498 poliester capacitors
Hi i have tda7498 and i want to change input capacitors and output capacitors. Should i change these two with same ratings 1000mf 63v or should i go higher? And what are the right wima capacitors to replace these output caps, their rating is 0.47mf 63v. Is the Wima MKS4 right one for this purpose. Thanks.
