i would like to change the 2 speed potentiometers on my pioneer turntable,the markings on both pots are as follows, NOBLE KCS -004-0 B500 Ω A=G
anyone know what rating they are please?
See if you can get the specs, hifiengine or vinylengine.
The pot does not look like it a high powered pot, based on the numbers it looks to be a 500 ohm pot.
Trying to find a pot that would be physically equivalent might pose a problem.
Look at standard sources like Mouser,Dig-key,Farnell etc.
Try cleaning the pot first with Deoxit fader lube
cheers,yes ive cleaned them twice.i have a very slight speed wobble,if i try to adjust the speed,it slowly creeps to the left,if i correct it it slowly creeps to the right,if i get it right it wobbles backwards and forwards,both on 33 and 45rpm.
i think these would work. http://www.mouser.co.uk/Search/Prod...tualkey65210000virtualkey652-PDB241E425K504A2
The Pots you link yo are 500k (500,000 Ohms) whereas I agree with rsavas, I think you need a 500 Ohm Pot.
Why not use a Multi-Turn Pot? Might not 'drift' as much.
VISHAY - 534B1501JLB - POTENTIOMETER, 2W 500R | CPC UK
Otherwise, some others to choose from...........
500ohm Rotary Potentiometers | CPC UK
Or....................................
Potentiometers | RS Components
