changing output capacitor value? what should I consider?
I was thinking of using 100uF instead of 47uF for the aikido headphone amp (high Z 9pin version: http://www.tubecad.com/2006/04/27/aikido_high_impedance_headphone_amplifier.png).
If I do that, would I be changing other values as well? if so, can you tell me what they are and if possible the new values?
I have a feeling changing output cap value would require other changes as well cause John Broskie has several versions of the schematic based on the Z.
thanks for the help.
