Changing DAC chips - Query
Ignoring such factors as voltages, i/v conversion, etc.....
Can I replace a 16-bit DAC chip (eg TDA1541A) with a different chip but 18- or 20-bit.
What happens to the extra "unused" bits ?
Are they automatically set to '0' ?
Andy
Is the data left or right justified ?
Is the MSB or the LSB extended ?
Can the source limit the wordlength or vary the justification and
can the receiving DAC do likewise?
For modern dacs it isn't an issue as the left and right data is expected to be in one serial form or another and there is a reasonable range of input formats available allowing one to set the wordlength and the justification to match the source. It is only when the left and right data is simultaneous or the dac is a mono device or some other anachronism that problems arise.
