Changing Capacitors - Adcom GFP-565 PreAmp, Which Ones?
Ok then let me ask this now that I have decided on a cap (Panasonic FM). When measuring across the soldered leads of the caps in the preamp I find 7mm between the - and +. Should I go with a tapped lead of 5mm or stick to the 2.0mm leads?
I know this sounds trivial to some but this is my 1st project and with all the specifics dealing with components I want to make sure I get it right the 1st time.
