Hello all
I've a loudspeakers plan that uses a Seas component.
I want to replace them with a vifa components.
How can i know what model of the vifa driver i should use instead.
thanks
thanks
You could find some similar Vifa drivers and drop them into the SEAS design, but the chances of it actually working properly are about the same as the chances of winning the lottery and finding Cameron Diaz waiting for you at home, ready to fulfill your sweaty fantasies.
In other words, you'll have to redesign everything from the ground up. If you want to use Vifa drivers, it would be best to use them in a design specifically made for them.
Say, how are prices for Morel drivers there?
subtle SY!!!!
<Big Grin>
I'm not sure I wan't to know how much morel drivers are in their home country, I'll have to look up the exchange rate and then I'll probably cry 🙂 (not that I've bought them yet, but I'm running out of excuses to procrastinate).
Anyway SY has a very good point, if you want to use vifa drivers you would be much better finding a kit/plan that's designed for vifa drivers, or just use the seas design with seas drivers 🙂
Regards,
Tony.
<Big Grin>
Regards,
Tony.
