Resurrecting a Magnavox CDB-650 with disc read error. I want to replace the caps on the transport’s PCB.
May I remove the CDM2 with its tray mechanism intact in order to access the PCB which apparently resides under the transport?
If so, how?
If so, how?
....progress. First discovery, transport is a CDM4. Second, removal is possible intact as a unit. Once screw toward the back of the transport removed, then the three that secure the faceplate of the unit to allow lifting the transport out and disconnecting the multi-wire connections to the main PCB
