CDM-4 spindle disc removal
just curios, but probably this question has been asked previously by many others DIYers, however I did not find any match regarding this topic.
I would like to ask if anyone of you managed and succeeded to remove the aluminum spindle disc from the spindle motor? Could you share your experience?
thank you very much.
Based on my experience, I will keep the mechanism in the freezer for at least 24 hours, so the metal parts would shrink, and therefore creating a gap between the the spindle and the disc sufficient for me to pull the disc out. May be I need to spray WD-40 to help pulling it out.
I would avoid removing it by heating...
Any suggestion?
wmincy
I'd try experiment with coolant spray on either the motor+spindle or the platter.
Try to not apply any strokes to the axle, you could damage the bearing.
Btw. there's still the additional top cover (Do not touch the lens) on your CDM. Remove that too.
