hai ppl.......
i really need some help here ........
i mistakely removed 2 SMD resistors during a clock installation to my CDP thinking tose to be the grounding caps.But they happen to be the resistor that connect to the lead of the crystal that goes to the filter.
I can't remeber the values of those SMD . Can someone help with this,surely someone will have the schematics for CD6000 .Pls tell what are the values and the connections or if possible pls e-mail me the schematics.
Now in service mode its showing 3 error :
when i on the player - Error 11 - Sledge Error
when try to play something - Error 2 - Focus Error or now and then - Error 10 - Radial Error .........
Even if the disc manages to spin now and then ther is no sound.
Pls help.......
thanx in advance
Amuthan
Pls help.......
thanx in advance
Amuthan
Hi
Probably one of them is 1 Mohmor so, it should be in parallel with the crystal
The other one could be between the output of the oscillator circuit (in the chip) and the crystal, and may be in the range of 100 to 330 ohm
succes
succes
