I have read that a simple cap inline on the driver should suffice for DC protection. When I emailed eminence directly and told them what I was doing they didn't seem to think a cap was even necessary.
Is it overkill or can I easily ruin a CD from a dc spike from the amplifier when running components in an active environment?
If I should run a cap is there a magic value that seems to work well or does it need to be calculated so its not interfering with the crossover points set on the active crossover?
