Mabe just look at replacing any op amps in the output stages and perhaps adding some rail to rail decoupling directly across the supply pins to same.
Depending on what's fitted that's probably the easiest thing to try out, and can make quite a (subtle) but worthwhile improvement. All depends on what's fitted.
