CD player won't play clear disks
I got a vintage Akai cd-a30 as a hand-me-down. The cd player sounds great, except for the fact that if i put in a disk with a non-clear center area, the CD player refuses to play and simply displays a "--" on the display. Btw, if i put in a cd with a clear center area (the overwhelming majority of my disks) the motor doesn't even turn. I opened it up and there does not appear to be any additional sensor besides the lens in the CD mechanism. Any thoughts? Thanks
-Sadim
i'm further confused. The cd player is currently doing a FANTASTIC job of working though a CD-r with a clear center. It also played the clear-centered "Horowitz-Favorite Chopin" without any problems. I tried covering up the middle of one of the clear-centered cd's which will not play with black electrical tape which did not help. I guess this has nothing to do with the color of the insert.
Any thoughts as to why certain CDs will play while others will not? Also, does anyone have a manual/schematic for these? Should I be looking at changing the caps? It was manufactured in 1985. I took the cover off and things are very tidy. Thanks
-Sadim
If the disc wont rotate at startup, that indicates a failure to get a focus servo lock.
In the case of some of the Philips mechanisms, for instance, the thrust-plate that the spindle motor shaft rests on wears over time, making the turntable sit too low, then the player cannot focus on some discs.
I'm not saying it shares a Philips mechanism, but it might suffer from a similar sensitivity. Check if it has a disk height adjustment.
Sometimes cutting a circular 'washer' of adhesive paper and sticking it to the reflective side of the disc, to lift the disc off the turntable by a few mils, helps to confirm this diagnosis.
Otherwise, a general tuning of the focus servo adjustments may be in order. Otherwise it may be the laser has aged, and doesn't like the less reflective discs in our collection. (Be careful about messing with the laser power adjustment if you dont have the correct service info - you can shorten its life severely by misadjusting it.)
My '84 Sony and '84 Philips both still play ANY disc.
steerpike,
it is in fact one of the many philips mechanism players. Should I adjust the height if it plays other CDs? Is there a decent guide online as to how to go about this?
Also, can you elaborate by what you mean by a general tuning of focus servo adjustment.
thanks for the replies.
-Sadim
Well the height problem can make it picky about which discs it will play.
There are lots of online free service manuals, but first you need to identify WHICH mechanism you have. Post a photo and someone somewhere will identify it for sure.
Corrrect adjustment requires at least an oscilloscope, but its an easy thing to do. Unless you can *see* the waveforms, its a hit and miss affair.
An oscilloscope also lets you see if the laser is still good (check the amplitude of the RF eye pattern)
As the player is old, it may have gone out of alignment - that's why I suggest general tuning - or checking - of the servo adjustments, such as offset and gain.
More importntly - if anyone else has been poking around inside it, you have no idea if they messed up the adjustments (this includes some so called qualified service technicians!), so it is prudent to do those adjustments yourself - then you KNOW they are correct.
