Hello. I am new to the whole Diy thing. I recently purchased an Exposure 2010s cd player and was wondering if there are any relatively easy things i can do to upgrade the sound.Keep in mind i am new so my
knowledge is relatively limited at this point. The one model up from the cdp i have uses a better dac chip. The Burr Brown 1704 as opposed to the 1716 in my player.Are these difficult to change.I believe this is the only difference between the two players.
Hi
Do you have a circuit diagram?
Also what opamps are in this cd player?
The best course is to improve capacitors, regulators, opamps and clocks. So a service manual will help alot
Brent
Brent
Unfotunately for you those two dacs are fundamentally different. The1716 is a voltage-output bitstream device; the 1704 is a true multibit, current-output DAC (and one of the greats.)
No drop-in swap I'm afraid. For a start, the 1704 is a mono chip - you one for each channel - and the 1704 also requires a current-to-voltage conversion stage. No trivial matter, and if you are in that deep you'd be fundamentally re-engineering the player.
Which doesn;t mean what you have can't be improved - look at the PSU for a start - but be aware there are distinct limits with the sound from the BB 1710/1716 family IME. You may be better-off selling your player and simply buyng the one you really want, IYSWIM.
