CCS with VN2222L
the LND150 http://www.supertex.com/pdf/datasheets/LND150.pdf is more appropriate to the 12AX7 single digit mA plate current
a HV PNP "ring of two" feedbck ccs or Zener/LED Vref hanging from the V+ supply is a natural choice, cascode if high perfromance is necessary (PMOS pass divice also possible)
with a bufferd output stage the bootstrap RC ccs doesn't require special silicon and may be good enough
