Which CCS is to prefer?
There is an article which compares different ways to make a constant current source.
But I can't find this article.
I need help to find it.
Thank you!
Thank you!
https://nathaliebeimler.com/tech/audio_amplifier_current_source_comparison.html
Among them, this is the best.
Thanks.
Those papers were the ones I was looking for.
Especially the first one.
Here is a simulation I did.
The two first use LT1004 reference diode. First is not cascoded. The second is cascoded.
The cascoded with LT1004 has the lowest impact from the signal at supply 1kHz.
TLV431 has also rather good result.
Two diodes 1N4148 has the poorest result.
One LED and the two transistors are not good either.
Split each 6.8K resistor into two 3.3K resistors in series. Then attach a 47uF electrolytic cap between (the middle node where the 3.3K resistors connect) and (ground), for every current source.
Or, install a LM7809 voltage regulator. +15V input, +9V output. Bypass the 9V rail to ground with 100uF. Then attach each of the 6.8K resistors to +9V instead of +15V. Perhaps think about whether you wish to change those resistors to 6800 * 9 / 15 = 3.9K instead of 6.8K. "Mountain View" does this except the voltage regulator isn't an IC, it's just a resistor and a zener diode.
- CCS methods compare
