CCS - Help!
I have a problem.
I have built, and had great fun modding the ultra-compact amplifier, based on EL84's as found on diyparadise.com
However, I got power-hungry, and decided to build a version with 6550's in the output stage.
The CCS was originally the venerable LM317, and performed well in the EL84 amp, however it's not going to cut the mustard in a 6550 version, because of the elevated cathode voltage, so I have swapped to the TL783C. This is where it all goes wrong.... I'll be damned if I can set a sensible cathode current. I've pulled the CCS out, and substituted a Resistor and big bypass cap, and the amp works.
The CCS on the bench (set to 50mA) works fine in isolation, until the simulated cathode (IE a power supply and resistor) gets to about 22v , then it "runs away" and allows too much current to flow. The TL783C isn't getting hot, it just stops regulating.
I've been round it with a scope to see if there's anything oscillating, shouted at it, scratched by head, shouted at it again, checked the ADJ resistor a million times, both the maths and electrically and now I'm losing sleep....
Any thoughts?
We may be able to help, but a circuit with the operating voltages attached are the minimum to be able to see what's going on. A sketch on an envelope, photographed or scanned, is fine.
Stability is always going to be a problem for IC regulators pressed into CCS duty. OTOH, it may be the 6550 going unstable. I would add a 10K G1 stopper and a 1.5K(3W) G2 stopper to the Beamer until you find what this is.
22V is right on the corner of the TL783 current-limit characteristic, so some kind of transient overcurrent, due to instability, needs to be checked out. could also try adding resistance into the cathode-to-783 connexion, & see if the behaviour changes.
<a href="http://s165.photobucket.com/albums/u68/andydoswell/?action=view&current=DSCF4544.jpg" target="_blank"><img src="http://i165.photobucket.com/albums/u68/andydoswell/DSCF4544.jpg" border="0" alt="Photobucket"></a>
Excuse the hastily scribbled diagram, which I scribbled hastily ...and trhe fact I've got the number on the TL wrong... which I can assure you is the right part 😉
I'm going to try a 0.1 across the thing to see if it behaves. There's a 10K Grid stopper in the circuit BTW.
Thing misbehaves, even if there's no 6550's in there , and just a resistor.
Thanks for your comments. I've ordered some more regulators just incase I've damaged these, but RS have delivered them to my ex-wife's house... I've ordered some more 😉
I've tried a 15ohm across the pot, that didn't help, but by the time I got to that stage, I may have abused the reg so much as to reduce it to a jibbering mess 😉 ... much like the designer at this stage 😀
