can someone show me, how to build mu CF with ECC88, power supply +/- 50 V or 100V, with gain 3, input res on my amp is 4,7Kohm (3,5V ,700uA)...
thanks
thanks
Hi trancy
A CF alone has no gain ( gain <1).
It has to be preceded (or followed) by a gain stage.
Federico
Federico
fscarpa58 said:Hi trancy
Federico
yeah ....like that...
I was trying to make a schematic in micro-cap, but probably Im too stupid.....
Hi trancy
Last year I was in Bled for my white week holidays
Beautiful place.
I'll send you a pic for a 6dj8 common cathode
followed by a CF.
But since a gain of 3 is very low I have to
attenuate the input or the output.
Federico
Beautiful place.
followed by a CF.
Federico
A mu stage has a CCS-loaded triode (although it should work with pentodes just as well) with CF output. Think about it!
Tim
Tim
Trancy,
Attached is a cathode follower followed by a common cathode stage. I was told that tubes such as 6DJ8, 6922, ECC88, 6N1P can be used for such a configuration.
Federico,
Would it be possible for you to provide values for the resistors using 6N1P and ECC88 tubes? I have a couple of 6N1P sitting here waiting to be used. 😀
Thanks!
JojoD
Federico,
Thanks!
JojoD
Beautiful place.
followed by a CF.
Federico
wau...I live near by Bled, next time we should meet...
Iam waiting for your sch. .....thanks a lot...
JojoD
what is the input resistance of the amplifier?
( I am supposing that this is a preamplifer
which will drive an amplifier)
ciao
Federico
ciao
Federico
trancy, I forgot
You have to put the volume pot in front of it,
obviously.
reference curves at
http://www.audiomatica.com/tubes/6dj8.htm
Federico
obviously.
reference curves at
Federico
fscarpa58 said:JojoD
ciao
Federico
My Leach amp input resistance is 20K ohms. I would like to use a 100K pot but 50K, 250K, 500K are also available. My tubes are 6N1P. Available B+ is 150V @ 100mA regulated.
Please, Thanks!
JojoD
JojoD
B+ 150 V is very low for the 6N1P.
However, I'll try something.
see you later
Federico
P.S. I wiil use the duncan model. If you prefer
something different send it to me.
see you later
Federico
see you later
Federico
Federico,
That is the psu I already have setup, duncan model is fine with me. I would love a unity gain but if not possible, your smallest gain design would be fine.
Thank you very much!
JojoD
P.S. Already have ceramic tube sockets, will look for suitable aluminum casing tomorrow. Will be waiting...
Excuse me, jojod
but if you want a unit gain cir then
schematic in post #6 is not good.
you need a simple CF.
Federico
Federico
Federico,
First of all, thank you very much for your time!
May I ask why you don't like the one with a 25db gain? I ask because I am really interested in that topology. BTW, those resistors are 2W right?
JojoD
JojoD
2W for 20k e 30k res
for the other ( 200, 1meg, 270k) also 0.2 W.
I like the topology very much but, in this case,
and with 6N1P, we need 300 V to have it working properly.
Owing to the constrain due to the rigid connection
between plate of 1th tube and grid of the 2nd, the working
point is not very good, that is high distortion
( 0.4% at 5Vrms out) and not very great max swing.
However it works and maybe you will like its
sound.
If you don't need gain the CF is advisable.
Federico
sound.
Federico
- Tubes / Valves
- cathode follower with gain
