cathode follower - please check my circuit
Please can you check my circuit diagram. It is cathode follower (approx. unity gain) using 6J1 valve.
I am not 100% sure of the following:😕
1. Connection of g2 - pin 6 to pin 5 ok?
2. Do I need to make one connection to either pin 2 or 7 or connect both together?
3. Values of C1 and C2. The circuit is intended to have cut off at 25 kHz.
PS don't worry about heater wiring - I have that part figured out 🙂
Looks good.
A few suggestions :
R1 can be reduced to , lets say 100k to reduce the risk of grid current. It won't affect input impedance as it's a "bootstrapped" circuit.
A "lead-out" resistor of 100 ohm should be used between cathode and cap to prevent
any tendencies of oscillating. For the same reason, a grid-stopper of 1k should be connected between the grid and the input. Both the lead-out and gridstopper should be
mounted directly in the tubesocket.
You might add 470k both to the input and output caps to ground, this is to prevent
"thumps" when connecting/disconnecting
It's OK
Connect them together.
Those capacitors determine the LOW cutoff frequency. The HIGH cutoff frequency will be far beyond 25kHz.
