cathode bypass caps suggestions please for newbie
tmhajw
2007-03-14 10:05 pm
Hi There
I've now built a phono stage, pre amp and a pair of Loftin Whites (from parts & schematics from Bluebell)- now I'm wondering about some 'improvements'... First up must surely be all those 100 micro farad cathode bypass caps in the phono & pre- they're all rifa electrolytics at the moment. Any suggestions please folks?!
Also what does bypassing the p/s electrolytics (pi filter) with small value polyester caps do??
thanks in advance....
Bypassing electrolytics with smaller film capacitors (.1uF seems to be the most common) is in theory used to better the high frequency performance. But some will debate that it can cause undesireable side effects if the value isn't chosen properly. I am unsure which to believe.
If your chathode bypass caps only have a couple of volts across them, you can try replacing the caps with OS-CONS. OS-CONS are a electrolytic-like capacitor that also has good high frequency characteristics.
Shoog
2002-08-15 10:16 pm
Eire
Go with a bypass cap. Something around 1uf and possibly a 0.1uf bypassing that again. What it achieves is to lower the impedance at high frequencies where inductance in the electro comes into play. Effectively the bypass takes over and the performance is likely to be almost the same as if the quality bypass were the 100uf cap.
If you go with caps designed for switch mode power supplies, I can't imagine you will hear a lot of improvement, but thats a matter for experimenting.
Shoog
jnb
2006-12-30 11:55 pm
Bypassing the cathode resistors in the phono stage reduces noise (and may be a necessary part of the equalisation). Increasing their value would be good in theory but bigger electrolytics are not the desired solution here. You might consider LED bias or battery bias.
Bypassing the power supply caps is a process itself based on compromise. For good and trouble free performance you should put your best electrolytics here and not bypass them.
ray_moth
diyAudio Moderator Emeritus
2004-01-27 8:55 am
Jakarta
To avoid using electrolytics as cathode bypass caps, you need to use a method for obtaining the bias that doesn't involve a cathode resistor. One possibility is using LEDs. I have no experience of LED bias but there are many others here who can probably help you. Morgan Jones's book Valve Amplifiers is useful on this subject.
Another possibility is fixed bias, requiring a negative supply for the grid (usually applied to the 'earthy' end of the grid leak resistor). The negative supply can be a battery or can be rectified and smoothed from the power transformer if it has a suitable winding.
tmhajw
2007-03-14 10:05 pm
The pre ( ecc82) in particular sounds a little bit coarse, the L-Ws are lovely, the phono stage not too bad- these are my first builds, and I feel LED biasing might at this stage be rather beyond me..! Adding smaller value caps to each cathode bypass cap seems like an easy quick fix,so which variety of cap?!
For the p/s electrolytics are ok? I was wondering what difference a large polyprop as the last cap would make?
Sorry if all this is a bit basic..!
