Castle microtower build with EL70
Well after much procrastination (and waiting for nicer weather....) the build has begun.
Dry fitting of the cabinet. 10° top. I decided to rabbet the edges to help with alignment. However I did this in two stages and moved the router fence in between. SO not as crisp a result as I wanted and the visible edges won't be tight, but the joint inside is tight. Also, the interior depth is off slightly compared to width by about an eighth inch. Second pic shows the batten to attach the bottom.....in case I get into the stuffing adjustment phase.
Reactions: cogitech
Time to get back at it. Felt arrived. First obstacle was fitting around the installed braces. Not much room. Using wood glue to attach. Traced speaker cut out onto painters tape and then sliced out the middle. Will do the second speaker tomorrow.
Wow. Feeling a bit like Rip Van Winkle. Virtually no work done until September. Finally got the drivers fitted and wired in series. Added a small round over to all edges instead of a chamfer to hide some of the inaccuracies in the edges. Driving them with an NAD D3020 v2.
I am very impressed with the bass response. Definitely 40Hz available. They are set back about 4 inches from the front edge of the desk. The stereo image with vocals floats about eye level and dead center. Thankyou Dave and Chris for the plans and everything else you have contributed to this site!
Reactions: cogitech and von Ah
Very impressed with your castle effort! ...especially the full-monte bracing you did, just like the plans. I tend to skimp and usually only do a front-to-back bracing, but even that takes forever using a drill press with a circle saw...great job!
First photo shows the stain applied to the side panels. Second photo shows them with one coat of varnish and playing away....
I think I am done with them 🙂
