Wow I didn't even seen this thread I know it's old but any info on what you wrote would love to know more if possible thanks in advanceOoh, another 'blast from the past'! 😉 Some folks were using Altec 1" compression drivers with just a 3/4" baffle thickness flare and the 1.4" with 1.5" back at least to the early '60s. I've periodically recommended this on HE forums since they're great for HIFI apps.
There's been some high end consumer offerings in recent decades, but don't recall the details or if they're still around.
GM
Hello sorry this thread is probably closed but would love to try any more info on it if possible if not thanks anywayI'm playing a lot with F.A.S.T. project for a while, and i was wondering about the ''C.A.S.T.'' alternative, where the Fullrange driver is replaced by a Compression driver...
In my case, that would be hornless, as discussed in that thread
http://www.diyaudio.com/forums/multi-way/300628-official-hornless-compression-driver-thread.html
But of course one can use a short horn as well.
In both cases i think the use of an DSP/EQ is mandatory; massive gain adjustements will be needed, steep xover slope, EQing, etc...
I didnt try it yet, but i think it might work good. Not quite sure about the upper end though, because the only CD that are going low enough (400-500hz) are most of the time the larger 4'' diaphragms, and they might not be at their best @ 10khz+ but still, i think we can get something pretty decent on 9 octaves, with extraordinary undistorted potential SPL output 😱
Also, the less expensive option (and maybe a better sounding one?) would be to use a 3'' diaphragm (2'' throat) along with a subwoofer that still in his comfort zone around 700-800hz, like the TIW250XS or the 8W1v3...
Food for thoughts!![]()
Nothing special, just rounding over a baffle hole to flare the attached CD driver to make a super tweeter horn.Wow I didn't even seen this thread I know it's old but any info on what you wrote would love to know more if possible thanks in advance
Thanks over on you tube someone is doing the cast thats stated in this thread you tube channel real world audio or Google search voice of Lancelot it's almost the same thing about what this thread is about you should check it out and let the one who started this thread that someone actually is doing itNothing special, just rounding over a baffle hole to flare the attached CD driver to make a super tweeter horn.
