Cascode driver
TUBESMAN said:
Like I said it is obvious you do not like cascodes.
Not true. I like cascodes for VHF receiver inputs, and have been considering a form of cascode for a high performance HF receiver mixer. I have this peculiar notion: use the appropriate circuit for the job.
Low noise is important in a driver because it is an error signal that will mask detail and it is the job of an designer to make a circuit better than it needs to be.
No, low noise is irrelevant in a driver. You do not "make a circuit better than it needs to be" by choosing a topology which lacks features you need, introduces problems you don't want and has good points which you don't actually need.
I wish I would publish all my circuits in a single magazine back in 1950'th, then repeat in 1970'th, and so on, but unfortunately I was born in 1957 only. 😀
Do you care who went the road through the forest in some direction the first? I don't. But if somebody cares sue me! I know this forest better so while you are gong to sue I will find the better way! 😀
I will make the bold assumption that we all have Morgan Jones Valve Amplifiers 4th Edition.🙂 . OK, lets go to page 101, figure 2.27. Any thoughts on converting this into a differential circuit like the Hedge driver on pg.505 ?
Is it as straight forward as it looks or am I missing something? Also, would it be OK if all the triodes where 6SN7's or should the cascode be a 6922? I need a low distortion driver with low output impedance to drive a high capacitance.
Thanks for the help.
with Mile Prower's kind permission.....
i was responding to Tubemans' post, he seems to want a cascode driver so i posted one such design......no need to reinvent the wheel....incidentally i have 6F12's and 6P15P's to try out your driver circuit.....that is slated for next year.....
6F12 was too much for a typical "power amp" sensitivity. If to add more feedback Edcor transformers started ringing wildly, or I had to add dominant pole compensation with longer time constant than I liked. 6F1P I believe will be right in ball-pack, I did not try yet.
Been there; done that -- Le Renard.
When doing the design for this, I figured that a hollow state cascode just might do the job here. This I borrowed from SS design practice, where you see audio cascodes quite frequently. I couldn't find any examples "in the wild", so I just decided to go for it. It worked out just as well as the SS counterpart.
Thought about a 6SN7-oid, but not enough gain (you lose half of it in an LTP) and the RCA manual provided info on the 6BQ7 -- designed for cascode service up to 300MHz, no suggested audio specs, but a good audio loadline can be found, even if the plate characteristic is a bit squirrelly (undocumented variable-u characteristic?) Has a u-factor that falls nicely between that of a 6SN7 and a 6SL7.
As for designing cascodes, it's a two stage voltage amp, so draw up some loadlines.
