Cascading Followers
Is there any reason one can not/should not direct couple cascaded CFs like this?
Yes, I mistakenly thought that I needed the Zout of the driver to be roughly equal to the Z of the filter for it to work properly. Though increasing the impedance makes for larger inductors Hammond does have the 155C at 60H for only $15 each which allows for nearly 10k impedance which reduces losses significantly.
I am also thinking that it might make more sense to locate the infrasonic in the main preamp to keep any record warp or cartride resonance out of the main amp.
