Carver PM-100 Schematics
Help! 😱
I'm working on a friend's Carver PM-100 Plate Amp, and can not find any (free) shcematics on the web. :bawling: The problem is that there is +12V of offset on the outouts, and I've replaced all the output transistors, but no change. Tried disconnecting both secondaries (+/- high Vac & +/- low Vac), but transformer sti8ll hums LOUD, like it's shorted. +/- measured DC Voltages are +54V and -6V. History is that this amp ran a set of outdoor spkrs, and the spkrs shorted, drastically raising the load on the amp.
Outputs WERE Toshiba 2SA1302 & 2SC3281 pair. Since I had a few rails of Motorola & On Semi MJL1302A & MJL3281As laying around, I upgraded to these instead. (I kept the older Motorola-labeled units for myself & gave him the newer On semi units! 😀)
Any help here would be appreciated. Thanks!! 😀
'73,
N8XO
Check driver transistors, high power resistors, PCB, bridges. Repair one channel first. In second channel temporally disconnect (desolder ) drivers and output transistors. (or remove fuses). Check quiescent current true output transistors. If rails are unsymmetrical, then your PS is overloaded.(hum).
