I just picked up a Carver PM-100 pro audio amp. Everything works great except the level controls on front wont move at all. They are stuck almost all the way up.
Someone reccomended buying some spray like this. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=341-200 Or should I Just take it to a local repair shop and see if they can fix it?
anatech said:Hi customsuburb,
That spray is good for cleaning contacts but will not help here. Did the unit get wet or is there a possibility the knobs were pushed in too far?
These may need replacement, not a real hard job.
-Chris
I won the amp off of ebay so I dont know if anything happened to it.
I'll probobly just take it into a local place and have them look at it.
Hi Greg,
No they are not the locking type. Basically, just inexpensive carbon pot. The grease may be very sticky or the knobs are pushed against the bushing.
Customsuburb,
Try to free the pots first. Pull the knobs towards you. They are push on plastic types. No set screw. That alone may free them. You may need a wide flat screwdriver. Put a business card underneath so you don't gouge the faceplate.
-Chris
Customsuburb,
-Chris
