CARVER AV-705x 5 Channel THX Amp RCA Input Jacks
I just scored a heck of a deal on a Carver AV-705x 5-channel amp:
The only problem with it (which isn't really a problem) is that sometime before I got it, a couple of the RCA input jack ground sleeves were removed. Look at the two left most input RCA connectors in the photo below:
I believe that these sleeves are removable if one is having ground loop problems. But once removed, they are easy to loose.
Does anyone know where I can get a couple of these sleeves?
Thanks!
