Ok, as said in the subject. If I would like to change the output voltage of this powersupply from 25 to 30 volts what would i do? Sure I want a good result but also a understandable answer...
THANKS!
this is the supply schematic, just scroll down to the end
http://myweb.tiscali.co.uk/nuukspot/decdun/gainclone6.html
THANKS!
The best you could do is actually download the datasheet for LM338. There is all you need to know. Besides that the output voltage is set by ((R5/R3)+1)*1.25
