Carbon material cables
"the individual insulation also much contributes to the high sound quality: no wild electron crossings between individual conductors subject to all kinds of boundary problems. The electrons move in one direction without side movements."
There may very well be substance behind this pedestrian formulation. Reducing the near surface charge density and a homogeneous charge distribution greatly benefit signal transfer quality in all parts, including cables.
Its a good thing that electrons know that they are doing RF and not audio and therefore don't do anything strange in the radio world then. Any insulation effects beyond linear losses at RF would be very obvious
You claim insulation changes surface charge density?
Do you have any proof of this nonsense or is it just something you pulled out of the blue for no reason?
And quoting this non-fact can not "justify" the "advantage" you claim.
Believe... believe... 😀
The polarization of an insulator (dielectric) does indeed change the surface charge density in the conductor, learn your electrostatics!! (Not that N101N makes much sense of course)
To be precise the surface charge density in the conductor changes to cancel the polarized material's surface charge due to the bulk polarization, given a fixed voltage (and thus electric field strength).
When a piece of dielectric is polarized in an electric field, charge is displaced on every atom a tiny amount, which leaves a net charge on the ends of the material. Everything is chock full of positive and negative charges, all balanced out until an external field acts on it...
In fact insulators commonly have stray electrostatic charges on the surface picked up from contact and friction and the environment, above and beyond polarization effects. Conductors can only have net charge at the surface, and only such that the electric field is always perpendicular to the surface(*) - insulators have no such restrictions, they can have embedded charges, surface charges, and also the polarization charges resulting from external fields.
Normally we only count net charge and ignore every neutral atom, but polarization is one of the things that requires consideration of how charges are arranged in space within a material.
Some materials are spontaneously polarized due to the crystal structure, others are deliberately polarized by embedding charges (which then form a field that creates permanent polarization), These are called electrets.
(*) if this isn't the case, a current immediately flows to restore this condition, basically keeping the interior of the conductor free of electric field. In electrostatics we assume steady-state has been reached.
the reason: I heard a carbon/graphite (I don't know exactly what material it was made form) speaker cables and it blew my mind. it was absolutely fantastic and the best so far I heard. I want to build something like that because it is very expensive. I want to experiment with carbon/graphite DIY cables.
Please name the manufacturer, curious did you A/B against other non carbon/graphite cables?
JMFahey,
Just because you don`t know or don`t understand something does not mean that it does not exist. Try to strengthen your awareness and ability to decide what is nonsense and what is not.
Mark Tillotson,
Magnetism not electrostatics. I said that the dielectric layer reduces the surface charge density in the conductor so what exactly is the problem?
To be more precise, due to the presence of the oppositely polarized insulator, magnetic field strength (conduction) will be decreased thereby electric field strength will be increased and distortion will be decreased (at any applied voltage).
I was commenting on JMFahey's point, which contradicted you...
So you claim the dielectric effect on the surface of the conductor changes the magnetic properies? How can it, the current is the same...
JMFahey,
Mark Tillotson,
Piling more nonsense over the original one won´t make it truer, just will make the nonsense pile higher.
Why would the insulation have a charge on it?
cbdb,
you are right, good insulators do not store excitable charges, however, although I don`t know anything specific about the Van den Hul cable, I think that the layer in question is not a "real" dielectric layer, it just has somewhat higher resistivity than copper.
JMFahey,
that whatever layer reduces the surface charge density (skin effect).
In the same system, as kinetic energy decreases, potential energy increases.
Damping is reducing the magnitude, velocity and amount of vibrations. A higher resistance means lower voltage, lower frequency, lower current (and lower distortion for that matter).
