GaoFei GF-FG016LBP Carbon Fiber Red Copper Rhodium Hi-End Binding Post 4 / pcs
Brand : Gaofei
HI-END audio Binding Post
10μ Rhodium plated for best signal transfer.
Made from red Copper
Adjusting Black Nut can be locked .
Housing Material :Carbon Fiber offer effective electromagnetic shielding
The Screw is 40mm long.External diameter is 8mm.
Suitable used in 9 mm--- 25 mm MDF wood or Amp back panel
Color: 2 black and 2 red.
Connections:screws locking
11.5mm diameter hole size
Weight : 300g 4pcs
Include Allen key .
Design In USA
USD100 1set 4pcs.
GaoFei GF-FG013SBP Carbon Fiber Red Copper Rhodium Hi-End Binding Post 4 / pcs
Brand : Gaofei
The Screw is 20mm long.External diameter is 8mm.
Suitable used in 1.5 mm--- 7 mm MDF wood or Amp back panel.
Weight : 200g 4pcs
Include Allen key .
Design In USA
USD90 1set 4pcs.
Visit Us online shop :AB-system online shop
"shielding" Give me a break! Fire your add writer and just push the "cool factor" They look like they will work fine. At least as good as the $2 terminal blocks I use.
carbon fiber is known to attract lightening
might be dangerous 😀
looks cool tho, and 90USD, could be worse
why do you say that? about the lightning?
asking not being a butt.
This is not $2USD made from brass,
This Binding Post is made from pure red copper Rhodium plated ,this material is very expensive.
Thanks you.
A&B SYSTEM HK
And for the function it needs to serve, totally ridiculousness and overkill. That is why I suggest you just focus on their cool look factor. I don't doubt the cost. People will pay it for the looks.
For those who have not thought about it, the end of these things is going to be connected to a speaker. Inside is probably cheap crimped fast-ons and a long length of copper plated aluminum in the VC and who knows what the crossover is built of. The other end is going to be connected to some iron wire .22 Ohm resistors and a big choke. (amp output filter). All you NEED is a decent tight connection. The $2 tin over brass posts work as well as any invented. I like the ones with a hex nut as I can be sure they remain snug.
This is solution looking for a problem that is perpetuating the stupidity that causes high end to not be taken seriously. Again, sell them as "cool looking" and you will be honest. Selling them as "carbon fiber shielding" is paramount to fraud. You have a well made product, be stand up.
Fishing with a carbon rod in a thunderstorm in the middle of a lake is known to attract lightning. 😀
I suppose "red copper" means "not brass". In other words, unalloyed copper of unknown purity.
I fail to see any point of using carbon fiber, nor how it constitutes "shielding".
Red copper is just another name for a copper alloy, very similar to what the old pennies were made of years ago.
In that case, here is an interesting thread....
http://www.diyaudio.com/forums/parts/214220-what-red-copper.html
Very good looking. If I were building a top-notch no-holds-barred loudspeaker or amplifier I could see myself using these. Not for any electrical or acoustic advantage, but simply for the cool/exotic element. The lock-nut is a useful feature.
This is complete BS, of course, and deliberate snake oil when you add "effective" into the mix. I completely concur with those who said that your product should stand on its own, for what it is.
I already order mine binding post direct from NASA, they are using a metal called Adamantium , they also bonded this metal with wolverine.
theoretically is understandable ......................😀
pure red copper, carbon, shielding ......... bunch of words that mean absolutely nothing
also bare in mind that pure copper oxidase very very easily, so i will still bet on silver as better conductor due also oxides easily but the oxide is highly conductive.
or better then LEAD , plain cheap lead but we have to keep it cool at 4.2K and it will became a superconductor
Sorry guys I am being sarcastic 🙄
Why only "red copper"?
Why not SILVER if it is supposed to be "Hi End"???
Because the pure silver is very soft ,pure silver is not good for made binding post.
Is the carbon fiber intended as insulation, thus "shielding" the user from electric shock or preventing an electrical short circuit?
I think the real issue here is language, and perhaps culture.
Oh, I c...
Silver 2.5 Mohs
Copper 3.0 Mohs...
Mohs gade 1-10.
In the world is very small prue silver binding post product,
majority is silver plated,etc CMC ,Furutech,WBT.......because prue silver is very soft , not good for binding post or other plug.
I only care about a good function, meaning how it holds the speaker wire etc
once its mounted I never see it again...well, almost 😀
so, yes, I would be more interested in photos of how it functions, instead of just fancy looks, ofcourse
just joking
I once had a carbone fiber fishing rod where it said, do not fish in.....
man, if only you hadn't made that claim about 'electromagnetic shielding' 😱
and btw, don't claim it to be pure coper either
it would have the same problems like you say about silver
you would not be able to machine pure copper
its brass with higher copper/alloy content, or something like that
now if we stick to the facts, maybe we are still looking at good speaker binding posts
just joking
- Vendor's Bazaar
- Carbon Fiber Hi-End Binding Post
