I'm curious about how the THAM10 would fare as a car th candidate, it's rather small form factor and higher tuning (which might wok well with cabin gain) make me offer them up as my candidate, they will however require processing to work as intended.
Now it should be said that hey are no subs, processed a by hpf@40Hz min24dB/Oct, and a lpf@150H min 24dB/Oct they work as best.
Martinsson's Blog -
The link above also contains some driver simulations, for other drivers give hornresp a try, all the data required is also in the link, if you feel they might be worth a go that is.
Martinsson's Blog -
