Which one should I get? My main concern is sound quality. I want something that sounds tight and accurate, which means it will probably end up in a sealed box. I have a JBL BP600.1 amp. It's 600 watts x1 @ 2ohms. Would this amp even be adequate to power a single Infinity Kappa Perfect 10DVQ or a single Brahma 10 MKII? Would a different sub be better for my application? Any help would be appreciated.
I owned a brahma 15mkI, and I have heard some infinity perfects.
The brahma is a killer sub! Incredible sound and output, small boxes, very accurate and a major Xmax!
The Perfect is also a good sub, sounds good, but a bit too polite - it can't play brutal when it has too.
But, everything stans or falls with the box you use!
Personally, I say brahma.
Another good thing is the tech support of Adire > outstanding!
The Brahma is in a whole other league than that Perfect 😀
I own a B15mkI and B12mkII, so I can vouch for them. The 10 is the only one I haven't got to play with yet 🙁
Wire it to 1ohm (your amp will run that fine) and get a nice ported box for it and you should have good output without using a whole lot of space.
Thanks for responses, so far it looks like I'm leaning towards the Brahma in a ported box. However, I had one more question.
For highs, I'm running a pair of Infinity Kappa Perfect 6.1 speakers and they're cut off > 80hz. Would a Brahma 10 MKII in a sealed box be able to play 70-80hz accurately?
Sorry for all the questions. I want to make sure I get the right sub. The last set of speakers I owned were two 12" Orions that were in a ported box. Everything around 70-80hz sounded distorted and anything below that was really boomy. It was ok for listening to rap, but I don't listen to rap. I occasionally listen to talk radio, and I'd have to almost shut the subs off, otherwise lower voices sounded horrible!
I want to make sure that whatever I build sounds accurate. I even went through the trouble sound deadening my truck with 3 layers of brown bread on the floor, 2 layers on the sides/doors, and one layer for the roof. I'd like a system that has flat response curve and that I can listen to everyday. At the same time, I'd like the ability to really crank it when I want to.
I agree that the perfect is not the sub to compare to a Brahma. The Brahma is definitely better. If you want to compare it to a Harman sub I would compare it to the JBL GTI.
However, for the power you list, I would honestly get a Koda sub. It is also XBL^2, and off of the power you have it should get just as loud as the Brahma.
I checked Adire's website and they had a helpful pdf for calculating the power handling of brahma subwoofers. They claim that a Brahma 10 only needs 700W in a .87ft3 box to reach full excursion @ > 30hz. So it looks like that amp *should* work. To be on the safe side, I emailed their tech support. Here's the email I got back. .
"Thanks for the e-mail! 600W is fine for a Brahma 10; for a sealed box and
that amp I'd go with a simple 1 cubic foot enclosure. Easy to make, and
will sound great and still get quite loud!
Thanks again,
Adire Tech Support"
Thanks again,
Adire Tech Support"
the B10 is able to perfamorn amazingly good!
but I do like the suggestion of the koda, if you want to save some $.
you could hulp to the acoustic visions forum for more adire freaks!
the koda *should* outperform the perfest as well, but the perfect is a good sub in its league!
That amp does over 600watts which would be too much for a Koda 10. But perhaps a pair... 😀
I'd go with Adire's suggestion! That should play to 80hz fine. My buddy had his B12 crossed @ 80hz to some 5.25" components. It sounded great... the upper frequencies sounded great and seemed to come from up front. This was both in a sealed box and a ported box.
- car sub, infinity kappa perfect or brahma mkII?
