I guess maybe you could parellel a few PC PSU together...one here costs around SGD$5.00 that would be around USD less than $3...cheapie considering the amperage and the price...
Sony Seperates
Hi All,
I rigged up a Sony car cd player at my mom's for her. She already had a mini system that was pretty good, but from the days before CD became that popular. Headunit was (I think) CDX44 line level out only - one of the first car CDs intended as an add on running off a wall wart with some rectification.
NOT hi-fi, but a hell of a lot cheaper than buying a new system
She was only going to play Tom Jomes on it anyway, but it's been running without a hitch for about 6 years.
Cheers
Paul
Hi All,
Cheers
Paul
i really wouldnt bother using car amps in house
youl never get the power supply you want unless u spend too much getting a high amperage one.
id just go buy a plate amp from partsexpress (they are Very cheap in USA)
along with an Av15 or something similar..
nahz...if you knew where to look...you can get a cheapie 100A Switchmode PSU from surplus sales...those for industrial stuff and power your amp with it...
if i were actually going to go ahead w/ this project, i would just get an electrician to wire it up for me. and by the way, how could for example, a 500w 5 channel stereo system be run off normal 240v, usually 12 amps, but when we want to use the same setup, only the amp is ruin off 12volts and we for some reason need 90 more amps than with a 240v system?
____
Jake
____
____
Jake
____
maybe he already has the amp but not the PSU...he could mod the amp to accept voltages that are higher though...forget about the SMPSU...and power it straight...
I need help with car to home stereo conversion
What equations would I use to find out how many amps I need to convert a car amp to a home amp. If i have, say, a 200 watt amplifier, how many amps does the transformer need to supply? I'm a little confused with all this so if anyone could help me it'd be greatly appreciated
is 200W the speaker output...or the power needed for the amp to run??? Because no amp is 100% efficient...some power is lost as heat...therefor the wattage the amp actually needs is a bit higher than the wattage put out to the speakers...
I really am not sure. The amp was givin to me as a present. I think it is a 200 watt output. Its advertised as a 200 watt amp. Would the company say its more? I dont know. But lets say its a 400 watt. It really doesnt matter, does it? I'm just wondering what basic physics equations do I need to convert it? Im a freshman in College and I took physics in high school and i know i could have done this back then, but since then i have forgotten the equations. I appreciate any help anyone can supply. thanks li
Hellow,
I have been following this thread with interest. What I would like to know is how a triaxial speaker (say, something as respectable as Sony or Kenwood) would perform when installed in a room of about 140 Cu Ft dimension? I would like to hear from members who have sound empirical knowledge in this matter.
r_s_dhar said:Hellow,
ummm.. sony sucks..... umm.. yeah...
Skinny Boy,
Didn't know that. Well imagine you received one of those heaven-made, non-sucking triaxials from St. Paul himself. How would it sound in my 140 Cu Ft room? A room of this size is apparently far bigger than the biggest car ever built. So what would this "extra" room mean?
Hellow Joe Dirt,
could you be more specific? What exactly do you mean when you say "low level"? Do you mean:
1. low quality
2. low output
3.low resolution in terms of reproduced audio spectrum
thanks.
1. low quality
2. low output
thanks.
I'm doing exactly what you suggested with almost no problems.
Quick story... My car alarm behaving funny, so I've had to disconnect it. So I brought my expensive bits of my car hi-fi in the house, as I know what it's like to have audio gear nicked from your car. 🙁
Expensive bits =
Rockford Fosgate Punch 300x 4 channel amp
Pioneer 12" sub (forgot the model number, but it will take 400Wrms) 😱
I thought, there was no point having it sitting there for no reason, and the sub was pretty new, so it needed running in.
I had a motorbike battery laying around, I put a charger on it (it only goes to about 3 amp charging current). I then connected the amp to the battery, and the 2 spare channels (the other 2 are bridged to the sub) on my amp to my normal Hi Fi speakers (with a HPF set on the amp).
I then connected my mixer and turntables to the amp, and it worked fine! No noise, very good sound quality, and enough bass to get me arrested.
I tried conectting it directly to my PC, and there was an audible 50Hz hum, so I connected the PC thru my mixer, put the volume on the PC to 100%, and used the mixer as a volume control. You can now hardly hear the hum since there is a really high signal to hum ratio when listening to MP3's. 😎
Using a battery is a good idea as it allows for large amounts of current to be delivered with no problems. I could have this thing drawing 20-30 amps if I wanted. 😎 My only concern is that I'm gonna kill the battery, but I leave it charging overnight, so I think it'd be hard to completely drain it unless I had it turned right up for quite a long time.
If I get problems with this, I could upgrade the charger or battery.
I can post pics if you guys want... Theres wires all over the place, but it works.
Also, just a quick question: I've had this sub for around 2 months now, and have been running it in at low power... How much longer should this speaker take to run in before I can run it at full power? 10 hours? 100 hours?
EDIT: Just gonna get another quick question in if I can, (sorry if I seem to be dragging this one off-topic, it's not intentional). My hi-fi speakers are 6ohms, and yet the manual for my amp says it runs at 4 and 2 ohms (and shows various speaker configurations involving 4 and 2 ohm loads), with no mention of 6 ohms anywhere. I'm not gonna damage my amp by using 6 ohm speakers am I?
Expensive bits =
Mike,
Interesting. What you say confirms that gut-feeling I have always had -- something which the Gurus and the measurement equipment may dismiss. Batteries supply clean, instantaneous power and car audio is uncluttered. As the saying goes, "what is not there cannot create noise." To avoid evils of misconstruction, let me hasten to add that I do not, for even a millisecond, think that car audio, in a living room, can substitute a 3-Way system. But, then, I do not know how else to describe that clarity that you get from car audio.
Mike.....6 ohm speakers are fine for the amp
24 hours is what we use to do to break in drivers
and you will eventually kill that battery (buy a marine gel cell)😉
DIRT®
DIRT®
At the moment I either have the car audio setup, or my horrible midi hi-fi setup... I know which one sounds better. Sub-bass also makes a big difference tho, I made a tune in Reason that sounded ok on my midi hi-fi, but I listened to it again on my car audio setup, and the bass sounded mushy and horrible. I'm now in the process of remixing the tune.
If I had more time and money, I would love a proper system, but being a student isn't really pay for a pass labs system at the moment. 🙂
If it sounds good stick with it... thats what i'm doing at the moment. 🙂 I've always wondered the same thing about car audio quality tho... You hear of these people paying megabucks for power cables to thier amps, and I've often thought... "car audio has none of these problems... there isn't even any chance of 50Hz (or 60Hz) hum.
JOE DIRT: Thanx for the reply... Glad to hear the ohms situation is ok. (I've killed a cheapy car amp in the past due to some 2ohm shenanigans) 🙂
Also, I'll wait till this battery dies before I get another one... The gell cell thing sounds good, but I'm only really having this setup until I get my car alarm fixed.... I'm gonna miss it in my room 🙁
Wow... 3 posts by me in a row... there is a reason however...
Just thought I'd let you know that i solved the 50Hz hum issue. I had the line-in on my soundcard on in the mixer, and as soon as I turned it off, the noise vanished completely. I've now got the amp plugged straight into the computer, and it's still working ok. 😀 😱 😎
- General Interest
- Car Audio
- Car stereo cheap alternative to big hifi systems
