Car Speakers to speaker plug on PC
Disabled Account
Joined 2008
Well, I just purchased some new speakers for my Mitsubishi Eclipse 2001 GT, Rockford Fosgate 80W RMS punch speakers, and after installing them, I was leftover with some stock speakers that still sounded somewhat decent in my car.
I know that this isn't a common thing to do nor is very efficient or wise. I have been browsing around and I obviously know I'm going to need an amplifier for this system to work. I have lots of spare parts running around case-wise and a plexiglass container is an awesome start. However I have to get the speakers working from off the PC first! I know this item will work but I think $70 is a little hefty for this small project.
ThinkGeek :: Pocket-size 50 Watt T-Amplifier
Many projects I've done require soldering or wiring with electric wires, I know my way around that sort of stuff. So I thought about building an amplifier for this project, I saw this simple and well recommended design but it was for headphones which I don't think will satisfy this setup at all. There is a modification for it where you add in a DC outlet plug into the wall, which would be fine for the project, but I still don't think this setup delivers the hard power that the purchased amplifier would.
http://tangentsoft.net/audio/cmoy-tutorial/
Anyway, I was just wondering if anybody could help me out with a project that will definetly work with a little tweaking and I'll post pictures soon, my phone isn't getting service gg christmas! Possibly willing to spend 30-40$ on a cheap amplifier that would get the job done, I'm sure a used one exists out there. But as of right now I need to know the converters that would be required, and probably a way to induce a decent amount of power into the system so the speakers would have adequate volume (aka a good custom amp design)
thanks alot!
Hello , I was posting what a serbian forum member proposed just yesterday for amplifying a line level signal in a car...
Philips
TDA1562Q 70W
TDA155xQ from 4x6W to 2x22W
TDA8560Q 2x40 @2 ohm
TDA8568Q 4x25W
from ST
TDA7374b 2x22W
TDA7375 2x22W
TDA7454 4x35W
TDA7560 4x45W
...when I realized that you were in need of almost any kind of amplifier , not restrained by low voltage Power Supply such as the 14 V in a car.
So first of all ,if you aren't going to find a used one ,look around and see if you have any transformer from a power of 50 W and up that you could use for this application.
Then consider that car speakers are usually 4 Ohm ,and that's an impedance not many amplifiers would like to reproduce without distorting at full power ,even if a good supply (big transformer , >10 A bridge rectification , big capacitors ) is used .
Search eBay for a TA2024 amp board. Same chip as in more expensive T-amps, for around $20, on a board ready to power up and use. Some vendors even include cables and and speaker binding posts. I'm not sure what to recommend for powering it. A quiet linear supply around 12V might be best, or possibly a 15V laptop supply fed through a couple of beefy diodes to drop it to a safe range. Like a 10 or 25A bridge rectifier, - terminal goes to 15V source +, + terminal to the amp. (~ terminals not connected) It should reduce the voltage by about 1.2 to 1.4 volts. If you have a small 12V gel cell, maybe inside a battery booster pack or UPS, that could work if you leave it trickle charging.
thanks alot!
I just got a car amplifier recently online, you can have a look for it.
