Car speakers for home audio.
simon5 said:
Yes it's suitable for a home subwoofer.
Sealed will work and ported will work too, but ported will need a medium to large enclosure, may be better to go with passive radiators.
thanks simon5.
it is hooked up right now in my car powered by an old school rockford amp. the enclosure is 2.25 cu ft, slot ported tuned to 28 hz as per JL specs.
now i am confident to buy a plate amp. plate amps are very rare in the philippines. i have to get mine from the US or get it from a diy'er who's selling a decent one though.
If you're going to listen movies with it, I would build a larger enclosure tuned lower, but you could start with the enclosure you have now to see if it's ok for you already.
With a larger enclosure, you lose some output but gain more very deep bass.
I used a 10" JBL GT4 http://www.motor-world.co.uk/show_prod.php?prod_id=5449 to extend the range of my PMC DB1+s. The box is undersized to produce a system resonance of 51Hz and is then equalized using a double integrator as per http://sound.westhost.com/project48.htm. The internal volume is only 18.1 litres less the basket. The undersized box / double integrator is subject to a patent. http://www.audioannals.com/04481662-Long-Wickersham-txt.htm The full document is available if you use "DjVu" http://www.djvuzone.org/download/index.html
(My understanding is that patents are effective for 20 years, so this one is no longer active).
This is a novel and (apart from the amplification) inexpensive way to extend the range of your main speakers. The double integrator equalizer means that the speaker needs 12db more power at 25Hz than at 50Hz, but 12dB less power at 100Hz than at 50Hz. This is a narrow band of operation so power requirements are not as great as you might first suspect.
I don't see any disadvantage in using a car sub for this project!
Tony
This remind me of a rather perverted idea i struggle too lay off my mind.
I have 2 of these:
http://www.rockfordfosgate.com/rftech/library/1998/5_Subwoofers/RFR2212-TS.pdf
and 2 of these:
http://www.rockfordfosgate.com/rftech/library/1998/5_Subwoofers/RFR2215-TS.pdf
A pair of midwoofer called Macrom Integra 224W (8,5")
and finally a pair of Morel 28mm tweets.
The idea are as following:
15" in separate boxes. 160L tuned to 23 hz (up too 50hz)
12" used as low midbass in 35L sealed (50-120hz)
8,5" in 25L sealed (from 120-3000hz
and the tweets from there and up.
Bi or maybe even triamped (eventually with hipower Plate amps on the woofers)
Maybe a tad expensive too build, but migth be worth it 😉
Or what?
Attached pic are just a rough drawing, done with paint
Hi again, I just got a couple of Infinity Reference 1230 12 inchers.
VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 3.40
BL (TM) . . . . . . . . 14.63
VAS (LITERS) . . . . . 78.50
CMS (µM/N) . . . . 195.40
MMS (GRAMS). . . . 174.21
MMD (GRAMS) . . . 167.15
FS (HZ) . . . . . . . . 27.27
QMS . . . . . . . . . . . 6.14
QES . . . . . . . . . . . . 0.47
QTS . . . . . . . . . . . . 0.44
XMAX (MM) . . . . . . 12.25
What can I do with them for a home theatre subwoofer?
I have got a US blaster usb-2100, seen in most stores for 419 euro, I bought in on sale for 60 euro's (and 10 euro's shipping 😡 ).
Check it out here: http://www.xs4all.nl/~loosen/us blaster subwoofer/
It's designed to play in a ported box of about 50 liter, in which it can have an f3 of about 32 hertz.
Closed is absolutely horrible because of the low vas.
I don't care if it's a car woofer or not, for 419 euro's it just can't be bad.
Looks like nice drivers for a sealed box.
Exactly what I was thinking. A sealed box of about 70L and then equalise the bottom end.
Tony, do you get enough SPL for HT use?
Also, tell me one thing. Are commercial subwoofers all equalised since most cabinets are rather small.
bobo1on1, nice looking sub driver there.
