I've read about the chip amps running off a dedicated sealed lead acid battery and how it eliminates the noise that's caused by the power cords. Does the same apply to car amplifiers? I can purchase a brand new JBL 60x4 (@ 4 ohms) car amp for $65 (retails for $170) and I already have a deep cycle battery I can use with it. I will be running the amp on a pair of NSB line arrays and using an active crossover, hence the reason for needed 4 channels of amplification. Do you guys feel this is a good idea or would I be better off buying a true home audio amplifier, with 4+ channels? Only problem is that will run me a lot more.
Any pros or cons are appreciated. Thanks.
