caps and diodes for the lm3886
I used NTE fast switching diodes for my prototypes....same basic specs/tolerances. You should be fine, but just to make sure I would see if I could cross-ref the diodes and see how close they are.
On the capacitors, you should be fine...just stay within the voltage tolerances....
I have used some "Crazy High" capacitance....with great results. I salvage alot of old capacitors, well parts in general for my projects, and try to use what I have lying around before build the final product....
Have fun!!
Wayne
I have also found that if the transformers are marked in some way, you can usually look them up on the internet. Many will have part/serial numbers printed on them.
I have several that I have salvaged from UPS units and older HiFi equipment.
