Capacitors quality for NON-OS dac with TDA1541
To mush transformers ?
Flemming J P said:
I started off with 1 TDA1541 S1, then added another one and it made quite a big difference more detail all over.
Each dac has it's own decoupling caps and LM317/LM337 regulators.
My goal is 4 in parallel.
Splitting up supplies to separate transformers also gives a nice improvement.
Currently I'm using 4 transformers and my goal is 7 :bigeyes:
2 for the CS8412 (2 X +5v)
2 for the TDA1541 (+5v, -5v and -15v)
1 for the Kwak reclocker (+5v)
2 for the output stage and I/V converter (+15, -15)
Hello,
i must ask, whay are so mush transformers good: 2 pieces for one power cascade. Do you have shure that this is more good if one transformer.
For my project i am calculated with 3 transformers: one for digital ( 2x2x5V ); one for analog ( 15 V )and one ( with two separate secondary outputs: 2 x ...V for tube anode voltage + 2 x heating )
What do you mean about my plans...
hifiwolf
