hello all- i am servicing a hafler 9500. the filter caps have to be replaced.
20000uf 100vdc. 92mm H, 63mm w, 31.7mm screw terminal spacing.
i can fudge the width a little bit, but height figure is firm.
mouser, digikey, allied and newark cannot help. any suggestions greatly appreciated.
regards,
s.hirschhaut, cet
regards,
s.hirschhaut, cet
I've had a look around and the only ones I can find are 109mm tall.
Can you reduce the voltage at all, I'm assuming that these are reservoir caps as 20kuF is no longer a standard value and would need to be replaced with 22kuF.
You are going to have a hard time finding them. 3 5/8" tall for 100V
I haven't seen in my searches ...
I do have Adcom 22,000Uf 100 Volt caps in stock now but are 4 5/8" tall
5" with the screw tops.
