I’m working on a Soundstream BXA1-10000D
The rail caps are vented .
They are 2200uf 100 volt .
The issue is I cannot find the caps anywhere the originals are 25mmx30mm
I can find 25mm diameter but the height is the issue all the caps I’ve searched are way to tall and the bottom cover will not go back on .
Any ideas on what to do ?
Looking at photos you posted previously, it looks like you could use larger diameter caps if you laid the center two in each group down and hard-wired them in.
The 25mm x 35mm caps won't work?
You may have to go with a lower value in the SS amp. If you do go with a lower value, make sure that, when the amp is driven hard into a load, that there is no increase in rail voltage (magnitude) for either rail (bus pumping).
- General Interest
- Car Audio
- Capacitor Question
