I found a couple caps out of spec when rebuilding this amp .
The caps are Sam young
Wondering if these would be a good replacement for the power supply filter caps ?
https://www.mouser.com/ProductDetail/647-UFW1E332MHD1TN
Probably not the best option. For the primary filter caps look for:
105° temperature rating
low or ultra low ESR
Would these be a better choice ?
what would be a good rating for the esr ? When looking at caps I’m not sure what to use as far as the esr goes
https://www.digikey.com/en/products...MI4KTYneCA9QIVR_fjBx3eVwD2EAQYDyABEgK_efD_BwE
Those are better. If you know the amp to be hard on caps, the following may be an even better (but more expensive) option.
https://www.digikey.com/en/products/detail/united-chemi-con/EGPA250ELL332MU35S/3528517
I suggest Ymin...
https://lcsc.com/product-detail/Alu...itors-Leaded_Ymin-LKML3001E332MF_C442845.html
50 cents each. 10000 hours @ 105°C, and Automotive rated.
I ordered the filter caps for the amp . The ones I pulled off the board are 3300UF 25V.
I didn’t realize this until I ordered them but the schematic shows 3300UF 35V
Wondering if I will be ok with the 25V or should I see if I can switch them before they pull the order ?
The higher voltage caps likely have a lower ESR. Will the 35v fit in the allotted space on the board?
- General Interest
- Car Audio
- Capacitor Question
