Capacitor Question
I’m rebuilding a Digital Designs Z2 .
The amp uses the 22uf 250volt bipolar caps .
Are these a critical part wondering if I can switch the values of these say to a 10uf or a 33uf 250 volt bipolar cap ?
I would use the Mylar caps but I don’t have enough room on where they sit in the board with all of the other components in the way .
You never stated in what part of the amp these are intended for. I'm only guessing that it's for the signal. Signal is usually only a few volts, and often many amps will still use a large crossover cap in place rated at 250v, even when a small volt cap will work. Where are these in the circuit? I wouldn't use a polyester cap in the signal.
Also, the link you provided is for a 0.22uF cap
In the first post, you wrote 22uF
Check the value again
