Capacitor in parallel with negative feedback resistor
This capacitor usually has two functions:
1. set the closed-loop HF roll-off
2. add some phase advance to aid loop stability
The first one is easy to calculate, as it is a normal CR response (near enough). The second depends on several other things, including stray capacitances so difficult to calculate.
Some people use a third option:
3. adjust to get a 'good' square wave response
