Capacitor Code: u22nJ2A
I have a film capacitor (5mm lead spacing) that's blue and has this written on top of it: "u22nJ2A"
There are other film capacitors around it which are written "u22J63" which i know are .22uF 5% tolerance and 63V.
Could the u22n also mean .22uF?
J is 5%, but what does the whole 2A stand for? perhaps 250V?
Help appreciated. :headbash:
- Timothy
22nF 5%, it could be a 63V part. If you can figure out who manufactured it you can then probably look up the data sheet which should remove all mystery.
Post a picture here, and tell us where it is used and that would help with sourcing a suitable replacement.
Thank you for the swift response Kevin.
So it's an 0.022uF/22nF 5% film capacitor?
I thought if it had the "u" before the 22, it would mean it's 0.22uF/220nF.
It is used in the coupling for a powered Studio Monitor (Emotiva Airmotiv 6)
Seems like cheap Chinese wholesale film capacitors.
The board receives XLR/RCA Line Input, and has LF and HF EQ adjustment knobs.
Here are some pictures.
http://imageshack.us/a/img843/3900/ji7a.jpg
http://imageshack.us/a/img855/2067/bgwz.jpg
Woah, you're right.
With the added "n", it would seem that the value becomes 0.022uF.
Whereas no "n", it would equal 0.22uF (based on results of google search).
What i don't understand is why adding the "n" would change anything when the 22 is still after the "u".
