Capacitance, anyone?
Hello all,
If anybody is looking for powersupply capacitors, try BG Micro (www.bgmicro.com).
Search for "The Stubby" (68.000uF/50V).
I ordered mine two weeks ago, and I received them today. Boy, do look the business!!. I guess this means my ampchassis is going to be a bit bigger!!
Even with shipping to Europe (the Netherlands) the price is incredible (I think I payed about 6,50Euro's per can including shipping and handling).
I am making 4 channels of Aleph 5, and there are some things I still have to locate (matched sets of fets).
Jarno.
capitance? does that sum up what a captain does in his job?;)
thanks for the hint, interesting opportunity.
You´d be better (cheaper) off to match the fets yourself.
Try Reichelt for some cheap fets. I paid 1.35€ for the IRFP240 from International Rectifier.
To be sure they come from IR (if it´s important to you) you better call them up to be safe.
Cheers
Jens
How many fets do you need to get 2 decently matched sets of 6 fets each?
I recall having read a lot of suggestions of how many fets you´d have to buy to get a certain amount of matched fets.
I still haven´t matched mine so...
Just do a search here and you´ll find many answers.
It definitely helps when you call the distributor or whereever you´re buying the fets and ask if they´re from the same batch.
That keeps the probability of having fets with more or less the same gate-source-voltage quite high.
Another thing is that not all fets from one amp have to be the same gate-source-voltage. You have to group the fets working as current sources and the "gain-fets" but you probably know anyway.
Cheers
Jens
Indeed you´re a damn party pooper, Magura.;)
Actually I haven´t looked at the size of the caps but at least they´re from Nichicon, a well known and one of the better cap manufacturers.
Of course size depends on temperature-rating and reliability.
Ever seen those Sikorel caps from Epcos (earlier they were manufactured by Siemens)? 105degree types that last "almost" forever.
I won´t buy any caps anyway, just bookmarked this bgmicro-shop.
Just for interest : What did you pay for shipping and all, Jarno?
Cheers
Jens - heading off for a beer:smash:
This capacitor looks very similar to one manufactured by United Chemi-Con (as far as I can tell the same company as Nippon Chemi-Con) and sold by Mouser - even the same U32D style, size, capacitance, voltage rating, and temperature rating.
Mouser sells it for about $36. What's the catch? Who knows.
Jeremy
Capacitance and FETS
Hello all,
Thanks a lot for all the replies. Regarding the FETs I have contacted Specmail (well known to all the dutch guys, I think), but I will ask AHE as well.
I have also had a look at the spec sheets of the big capacitors, they have a ESR of 9,4mOhms and a rated ripple current of 24,55A. And yes, they are by United Chemi-Con. They also make a more "elongated" type which has a ESR of 6,5mOhms and a rated ripple current of 27,67A. The type is indeed U32D. Capacitors by other brands are similar:
Panasonic G-AA: 7,7mOhm 14,27A or 14,15A (depending on case)
Nichicon NT: 27,5A (68.000uF/35V)
Nichicon NR: 36,0A
So yeah, they're just your "plain-vanilla" type capacitors, but looking at the prices of the other brands, I think they'll do just fine. I paid about $38,- shipping and handling. So all in all I paid €6,50 per can which is very little, I think.
Jarno.
Magura said:
Not to be a party killer byt those 68,000uf 50V caps are about half the size of rifa 68,000 uF 50V.
Im quite sure that if it was possible to make a good and reliable cap half the size....rifa would have made it half the size.
Not to blow your hat but the N type BG caps (which is their best grade) are much smaller than the same value Standard BG grade.
I'm surprised they still have those caps. I bought the whole case myself last summer and they seem to be very well built (quite heavy too). Also like those oversized terminals. I bet Rifa doesn't make them like that;)
Yeah, screw terminals. Because the term "computer grade" dates from when men were men and computers came with massively inefficient linear power supplies. These days a computer doesn't need anything other than some basic hi-temp radial electrolytics (or OSCON).
Have you put any of those you bought to use yet?
If you say ok for those caps, im gonna get a box of them as well :)
Magura:)
