cap sub
27000 pf is .027 ufd and is probally a frequency setting part as opposed to a bypass cap.
Is this a phono pre amp? If so the value is quite important. Silver mica caps are real good quality parts. I would be tempted to use the same kind. Really we need more information, like schematic, or at pictures of the inside. Please provide the brand and model.
Silver-micas are generally excellent audio caps and lose nothing with age. They're also usually close tolerance. I'd stick with it. If I just couldn't help myself I'd only replace it with polystyrene, polypropylene or Teflon, in that order. I don't have the blind respect for Teflon that some do ;-)
In more detail, silver-mica caps have somewhat more dielectric absorption than you'd expect, given their very low dissipation factor, but it doesn't translate into any specific audio complaint.
