Cant figure out Feedback Path Sansui 7000
According to block diagram, this old cap coupled Sansui gets it feedback unto TR802.
Question: Is the feedback network the C804/R806 connecting emitter to ground or does the feedback signal come through R808 to the collector of TR802, with "balancing" taking place through C803 Collector to base ?
Sorry - if this is obvious, I am just begining to learn, usually it is clear what the path is. Thanks!
The 3.3K R809 and the 100 ohm R805 make the voltage divider effectively adding feedback on the emitter side. C804 and R806 are for bias.
This is like a typical tube frontend where you inject negative feedback into the cathode of the first gain stage.
